Activity Forums Apple Final Cut Pro Legacy Can’t run FCE
  • Can’t run FCE
    Posted by Dunwoody Lampton on September 14, 2008 at 8:57 pm
    After beginning and working with a FCE project for the last several days
    I opened the latest version a short time ago and got this:
    “The application cannot continue. Another application with an
    identical serial number is already running on your network.”
    I am operating FCE HD 3.5.1 on a PowerMac G5/Dual 2.5 GHz (Motorola)
    which had been previously partitioned into 10 disks by the original owner.
    I installed FCE on one particular partition and used it for many months
    until that partition “crashed” and has no longer been operable.
    I was able to trash the application from that partition, and I reinstalled
    FCE on a different partition.
    The FCE application exists on NO OTHER PARTITIONS but the one
    I have been using for many months. Why is the system sensing the
    application on another part of my network?
    Thanks in advance.
    Dunwoody Lampton replied 18 years ago 3 Members · 4 Replies
  • Miriam Moran
    September 14, 2008 at 11:01 pm
    I haven’t experienced this exact set of circumstances, but I have moved FC from one computer to another, and I had to “deactivate” the first installation before activating the second one. I’m guessing you can’t run the first one (from your description) so you’ll probably need to call Apple and explain your circumstances, they can (I’m pretty sure) deactivate your serial number so that you can activate it on the new installation.
    Good Luck!
  • Dunwoody Lampton
    September 14, 2008 at 11:31 pm
    Thanks for such quick response! But I think I’ve found the solution:
    At various times during the past 2.5 years I’ve had FCE 3.0 and 3.5.1 installed on both a PowerBook and a PowerMac simultaneously, and
    used both successfully.
    Once in a great while I would get the warning I’ve been struggling
    with today, but eventually it would “go away” and all would be well.
    For the past two hours I have mounted and unmounted the partitions
    on my PowerMac, verified the partitions and repaired those requiring
    such.
    I’ve disconnected the LaCie drive that contained my video and project
    files.
    I’ve restarted 12 times.
    No luck.
    Then, I turned to my PowerBook and noticed that I had opened
    FCE 3.5.1 earlier today on it and that it was still running.
    I closed FCE on the PowerBook, restarted the PowerMac, opened
    FCE on the PowerMac and it worked.
    My only conclusion (or guess) is that, because the same
    version of FCE with the same serial number was open and
    running on both computers at the same time, this was detected
    by Apple via the internet, since both were hooked up to
    active internet connections at the same time, also.
    Thus, Apple is capable and able to send out this warning when
    it detects, via the internet, this type of situation exists.
    Without the two, simultaneous internet connections on both
    the notebook and desktop, how could the desktop version
    “know” that the notebook version was running?
    If anyone else has a better explanation, I’d love to hear it.
    Thanks again, Miriam.
  • Walter Biscardi
    September 15, 2008 at 12:11 am
    [Dunwoody Lampton] “My only conclusion (or guess) is that, because the same
    by Apple via the internet,”
    Not via the internet, via your local network. If both machines are running on the same network, i.e. wireless router or cable modem, then FCE will see the same serial number on both machines. Technically you are only permitted to have the software installed on one desktop and one laptop at any given time.
    Even there, you can only operate it on one machine at a time.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Dunwoody Lampton
    September 19, 2008 at 2:51 pm
    Thanks, Walter.
    So much for my Conspiracy Theory.
