Activity Forums Adobe Premiere Pro Can’t resize UI window
  • Can’t resize UI window
    Posted by Robert Withers on September 1, 2019 at 8:40 pm
    Hello, I’m working with Pr 2019 on an underpowered Macbook Air (away from home) and the project windows come up too big, particularly the height. I can’t resize the window to fit on my screen cause I can’t get the cursor onto the bottom edge.
    Not the green dot issue — that still leaves too much of the UI off and below the screen.
    This might have happened when I plugged in a TV as monitor — but that’s disconnected and I’ve restarted. The Macbook Air is set at maximum and appropriate resolution for the display.
    The Welcome screen is fine, but when I open any old or new project window it falls off the bottom of the screen.
    What’s the magic needed here?
    Robert
    Robert Withers
    Independent/personal/avant-garde cinema, New York City
    Robert Withers replied 7 years ago 2 Members · 3 Replies
  • Robert Withers
    September 1, 2019 at 9:59 pm
    SOLVED! By resetting preferences and fiddling a bit more.
    Robert Withers
  • Todd Perchert
    September 4, 2019 at 6:32 pm
    Yep. Trash the prefs. Also, I would save a custom layout. I have one for dual monitor and single monitor. When I need to, I revert to it.
    TC
  • Robert Withers
    September 4, 2019 at 7:55 pm
    Thanks, Todd.
    How do you trash the prefs in Resolve?
    R
    Robert Withers
