Activity Forums Adobe After Effects Cant render
  • Cant render
    Posted by Efi Or on March 24, 2010 at 2:33 pm
    Hi everybody.
    I have an annoying problem with rendering from AE to my pc.
    I choose render setting, render module, press on the “render” button – and everything goes smoothly. I can see the render bar moving forward.. UNTIL the effects part, then the render bar stops moving.
    AE is not crashing, and I can still press on the “stop” button, its just that the render bar WONT MOVE.
    I tried to give it a full night, 12 hours, and nothing. always stops at the same point.
    and… if I’m trying to ram preview the movie…its ok.
    so any ideas guys? I cant finish the movie like this!
    Efi Or replied 16 years, 6 months ago 2 Members · 6 Replies
  • Efi Or
    March 24, 2010 at 2:52 pm
    I’m updating the AE right now, thank you dave.
    about the openGL, right now its “openGL – interactive”, to what should I change it?
    Off
    Wireframe
    Adaptive Resolution – OpenGL Off
    im not using multiprocessing, I dont know what it is.
    the two links you wrote in your post are dead by the way.
  • Efi Or
    March 24, 2010 at 5:04 pm
    “To get the most from After Effects CS4 out of your computer with eight processor cores and a 64-bit operating system, you would have 32GB of RAM…”
    eight cores? how is it possible? I thought that the max cores right now is 4. even the newest i7 got “only” 4 cores. and 32gb ram? I have never seen more than 8gb to sell. I dont get it.
    anyway I got win7 64bit, 8gb ram and intel Quad Q9450.
    I think ill try the multiprocessing, maybe it will help.
    the opengl by the way is OFF, and I updated to the newest ver of AE.
    thanks a lot Dave, Ill keep you update.
  • Efi Or
    March 24, 2010 at 5:21 pm
    damn thats a lot of processing power… 8 cores…wow.
    I feel so lame now with my poor intel 4 cores.
    hehe. anyway thanks alot Dave.
    btw, the “Prevent DLL address space fragmetation” is ON. no idea what it is, to keep it on?
  • Efi Or
    March 24, 2010 at 6:24 pm
    ok Dave I CAN render now with no problems but one.
    after 30 seconds of the movie the render will stop.
    there is nothing to do to effects…even if Ill render simple footage.
    seems like after 30 seconds (of the movie, not real time) there is not enough ram or something else.
    I tried to disable multiprocessing and it wont work.
    any ideas Dave?
  • Ahmed Abd el-rahman
    March 24, 2010 at 7:50 pm
    hi !!! if you are using CS4 try this :
    1 – Enable caching frames to disk by selecting the Enable Disk Cache preference
    2 – Purge RAM and disk caches (choose Edit > Purge > Image Caches)
    For the best performance, select a folder that’s on a different physical hard disk than your source footage. If possible, the folder should be on a hard disk that uses a different drive controller than the disk that contains your source footage. The disk cache folder can’t be the root folder of the hard disk.
    if thing changed Inform me Thanks
  • Efi Or
    March 25, 2010 at 5:25 am
    no Ahmed, unfortunately it didnt.
    I stopped trying though. it aint that bad.
    I CAN render 30 secs each time, so Ill render my movie 2-3 times, thats it. then Ill join all the part with Premiere.
    thanks for trying, especially you Dave.
