Activity › Forums › Maxon Cinema 4D › Can’t render transparent background in animation
Posted by Mitch Hardison on June 27, 2010 at 1:28 pmHow do I render a transparent background in my animation. I searched the forum but could not find a good answer
Paolo Ciccone replied 16 years, 2 months ago 2 Members · 3 Replies -
Paolo Ciccone
June 27, 2010 at 2:51 pmYou need to use a format that supports the alpha channel. The easiest and safest way to do that, I assume younger gonna composite your animation later, is to render to a sequence of frames, using PNG or Tiff, and then import the sequence in your NLE After Effects. AE recognizes image sequences as clips so the process is, no pun intended, completely transparent.
You could render to QT with a codec that supports alpha but you would complicate matters. Image sequences are your friends.
Paolo Ciccone
Pret-A-3D
https://www.preta3d.com
https://www.paolociccone.com -
Mitch Hardison
June 27, 2010 at 5:00 pmawesome! Thanks a lot. one more quick question. can i take a grunge texture image and apply it to the face of my text to give the text a grunge look. the texture is a jpeg.
Paolo Ciccone
June 27, 2010 at 5:47 pmI’m not an expert on C4D, I work with Blender, but there should not be a problem. At the worst you should convert the text to a mesh, UV map it and then the texture will flow correctly. Technically there is no limitation. How it’s done in C4D? Other people will surely chime in.
Paolo Ciccone
Pret-A-3D
