Activity Forums Adobe Premiere Pro Can’t render timeline
  • Can’t render timeline
    Posted by Blast on March 8, 2006 at 2:36 pm
    Have a small project, 80+ stills with a simple cross dissolve between. All stills are JPEGs automated to sequence from project bin. I have a “red” line that tell me it needs to render. It wont.
    Just for grins I exported to DVD from the timeline. It works fine and looks fine on a home DVD player. I added some dv video and put a simple color correction on it to “get a red line” it wont render either. Any suggestions?
    Running PP 1.51 and my system specs are below.
    ProStar 5614 Laptop
    P4 Northwood 3.2 800FSB.
    1 gig 3200 DDR SDRAM
    2 7200 rpm,60 gig HDD
    1 250 Diamond Max HDD
    Teac -R-RW burner
    Sony DRU-510A -R/ R burner
    ATI 9600 MPRO 128 meg.
    17″ AUX. monitor
    13″ NTSC monitor
    DV break-out
    Bella keyboard
    Blast replied 20 years, 6 months ago 2 Members · 7 Replies
  • 7 Replies
  • Blast
    March 8, 2006 at 3:52 pm
    It renders fine in Premiere Elements 1.0
    ProStar 5614 Laptop
    Teac -R-RW burner
    17″ AUX. monitor
    13″ NTSC monitor
    DV break-out
    Bella keyboard
  • Roger Averdahl
    March 9, 2006 at 1:53 pm
    Does your Work Area Bar cover the stills you want to render?
    When you want to render your Timeline Premiere Pro renders only the media that is covered by the Work Area Bar.
    /Roger
  • Blast
    March 9, 2006 at 2:06 pm
    Yep, check it. no help still a red line. thanks for the input though
    ProStar 5614 Laptop
    Teac -R-RW burner
    17″ AUX. monitor
    13″ NTSC monitor
    DV break-out
    Bella keyboard
  • Roger Averdahl
    March 9, 2006 at 3:10 pm
    Can you render any Project?
    If yes, try to import your old Project into a new Project.
    /Roger
  • Blast
    March 9, 2006 at 5:11 pm
    Thanks Roger, I’m on it
  • Roger Averdahl
    March 9, 2006 at 7:19 pm
    You’re welcome!
    /Roger
  • Blast
    March 12, 2006 at 4:54 pm
    Nested the sequence in to a new one, added some more stills to finish the project. That did the trick and all is well. Thanks for the idea, as I was toooooooo close to the problem. Still dont know what happened but it got me down the road so to speak.
    Harry
