Activity › Forums › Adobe After Effects › Can’t render quicktime out of after effects
Posted by Matt Macdonald on January 23, 2013 at 12:01 amYesterday I rendered 3 things as an .mov file. Today start up after effects, and I created a REALLY important project. I need to render it as an .mov but there just isn’t the option. Under render format there is no QuickTime option. Please help ASAP, because this is a VERY important project.
Antonio Cerro replied 12 years, 7 months ago 4 Members · 6 Replies -
Vishesh Arora
January 23, 2013 at 9:34 amMatt
This happens when quicktime is not installed. But you already rendered some files as.mov which means it is there on ur system.
Try installing it again with updates. It may help. Also check whether it is available in Adobe Media Encoder or not?
Vishesh Arora
3D and Motion Graphics Artist
Films RajendraBlog:
https://digieffects.wordpress.com2011 3D Demo Reel:
https://www.youtube.com/watch?v=lHPgIJU_BR8 -
Todd Kopriva
January 23, 2013 at 4:36 pmSee this:
“Troubleshooting QuickTime errors with After Effects”———————————————————————————————————
After Effects team blog
Matt Macdonald
January 26, 2013 at 4:46 pmI figured out the cause of the problem. I did a disk clean-up and ever since then after effects has had countless errors. If anyone has a solution to this PLEASE help. I have tried deleting both after effects’ and QuickTime’s preferences. I have tried every single thing I have read and NOTHING works. I am so desperate to get this working and any help would be appreciated.
Todd Kopriva
February 4, 2013 at 11:08 pm> I did a disk clean-up and ever since then after effects has had countless errors.
That makes it sound like you accidentally removed some essential files. I suggest uninstalling and reinstalling both QuickTime and the Adobe applications.
Matt Macdonald
February 5, 2013 at 1:27 amI have already reinstalled both after effects and QuickTime. this didn’t seem to fix the problem.
Antonio Cerro
January 27, 2014 at 5:48 amI had the same problem this morning, I realized that the .mov files weren´t aloud to open with quicktime as default, so I changed it (right mouse button/open with/choose default program).
It worked for me.
