Activity › Forums › Adobe After Effects › Can’t render quicktime (.MOV) files to local hard drive?!
Oleg Burinsky replied 10 years, 3 months ago 9 Members · 12 Replies
Peter Meng
April 17, 2015 at 11:32 amI was having a similar problem where After Effects, Premiere, and Sony Vegas could not create QT files on certain drives. Thanks to Ray’s tip above this is what I discovered.
It looks like QT will only write to drives with a unique name. My volumes were set up as follows (looking at Windows File Explorer)
Local Disk (C:)
New Volume (F:)
New Volume (G:)
New Volume (H:)I could create files in C: and F: but not in G: and H:.
After changing the Volume names so they all were unique:Local Disk (C:)
SSD Volume (F:)
Main Volume (G:)
New Volume (H:)I could now create files on any drive.
To change the Volume name, right click on the drive and select ‘rename’ or bring up the properties window and rename it there.
Oleg Burinsky
June 6, 2016 at 4:45 pmIn my case it was the opposite. My drive S:\ was called ProjectsSSD. I had to leave it’s name blank in order for quicktime to start rendering to this drive.
Had this problem for over a year.
