Activity Forums Adobe After Effects can’t render out!?
  • can’t render out!?
    Posted by James Barnham on December 8, 2008 at 7:24 am
    Hi
    I got a wierd issue I’ve never seen before. I am trying to make a simple output.. and it won’t render. Have tried to chose all format there is but AE simply won’t render an output. I can preview render, no problem but as soon as I hit export it stops. it counting time but no frames. have tried with different projects to..
    anyone knows what this thing could be, it just happened to without changing anything to.
    james
    James Barnham replied 17 years, 9 months ago 2 Members · 2 Replies
  • Jeremy Mullen
    December 8, 2008 at 5:14 pm
    Simple question, but it needs to be asked – you are not ‘exporting’ via the File menu, right? Of course you should be going out through the Make Movie option in the Composition menu-
  • James Barnham
    December 8, 2008 at 5:24 pm
    No I am going through make movie option.
    I am using vista 64 and cs3.
    J
