Activity › Forums › Adobe Premiere Pro › Can’t Render One Movie
  • Can’t Render One Movie
    Posted by Lucas Windsor on May 29, 2009 at 4:13 am
    I am having issues rendering a movie. Its only 8 minutes long, but for some reason it errors out each time. I thought it might be the setting, but I tried another vid with the same settings and it rendered just fine.
    This particular movie was moved from a PC to a Mac and all the video was converted to QT’s. I am trying to output it on to DVD.
    It encodes the first minute or two then stops, and idea what is wrong.
    Here is the error I get when trying to encode.
    – Source File: /Users/richardwindsor/Library/Caches/TemporaryItems/Bioptic Driving Movie Complete Reedit 04172007_1_8.prproj
    – Output File: /Users/richardwindsor/Desktop/Bioptic Movie DVD Output/Bioptic Driving Re Edit dvd version.m2v
    – Preset Used: NTSC Progressive High Quality
    – Video: NTSC, 720×480, 29.97 drop frame [fps], Progressive, Quality 4.0
    – Audio: 48 kHz, 16 bit, Stereo, PCM
    – Bitrate: VBR, 1 Pass, Min 1.50, Target 4.00, Max 7.00 [Mbps]
    – Encoding Time: 00:01:27
    Fri May 29 00:07:57 2009 : Encoding Failed
    Error compiling movie.
    Unknown error.
    Eddie Lotter replied 17 years, 4 months ago 2 Members · 3 Replies
  • Eddie Lotter
    May 29, 2009 at 2:01 pm
    Have a look at Error:Unknown error for some possibilities.
    Cheers
    Eddie
  • Lucas Windsor
    May 29, 2009 at 7:53 pm
    Thanks for the info.
    Turns out that there was one AVI file that had some issues. I converted all the video to newer formats but I must have not replaced this one with the new one. I even had the new one already made. I just swapped it in and presto…it all works now.
  • Eddie Lotter
    May 29, 2009 at 10:19 pm
    [Lucas Windsor] “Thanks for the info.”
    You’re welcome.
    I’m glad you found the problem.
    Happy editing. 🙂
    Cheers
    Eddie
