Activity › Forums › VEGAS Pro › Can’t Render Nested Scenes
  • Can’t Render Nested Scenes
    Posted by Mike Thomas on August 15, 2010 at 10:20 pm
    I have a 2 hr feature that is broken into individual scenes only. I need to render the whole movie together to get it on DVD. It was suggested that I import each scene “nested” into a new project timeline then just render them all into one movie. I started to import each scene and line them all up on the timeline in there correct order. It was going great UNTIL I had about half the movie on there. That’s when it all fell apart. Basically everything just freezes up and I can’t import the rest of the movie. I read on the forum to lower my preview RAM and “number of threads”, which I did, but that didn’t help much. What should I do? I have a hefty, dual core computer.
    I can break the movie up into 2 or 3 “parts” without a problem and “link” them together in Architect but the final DVD will just jerk as it plays through each part. Help would be greatly appreciated!
    Mike Thomas replied 16 years, 1 month ago 2 Members · 3 Replies
  • Mike Thomas
    August 16, 2010 at 1:49 am
    After more research I’m learning that others are having this same problem and it seems that I may need some critical Vista updates having to do with the way Vista handles RAM usage. Still though…if anyone has any thoughts I’d like to hear them. Thanks!
  • Mike Kujbida
    August 16, 2010 at 9:46 am
    Here’s two things to try, both of which I’ve done successfully when nested files failed to work for me.
    #1. If your project is SD, render each section to DV-AVI using Best mode.
    Then combine the rendered AVI files into a new instance of Vegas and render for DVD.
    #2. Open scene #1.
    Start a new instance of Vegas.
    Copy scene #1 and paste it into the new instance.
    Close scene #1 and open scene #2.
    Copy scene #2 and paste it into the new instance.
    Repeat until all scenes are copied over.
    Render to DVD.
    Remember to save the new instance after each copy/paste.
  • Mike Thomas
    August 16, 2010 at 2:53 pm
    I’ve found that the problem with copy/pasting scenes is that I lose all my FX when I do that. Some scenes I’m done working on have a dozen tracks or more with both audio and video effects applied. Am I missing something with copy/pasting?
    The project is HD not SD.
    I researched more and found that it’s necessary to have the Service Pack 1 upgrade for Vista which my editing computer doesn’t have. Once I get that installed today hopefully my machine will stop freezing up and giving me “low memory” errors.
