Activity Forums VEGAS Pro Can’t render movie – file too large
  • Can’t render movie – file too large
    Posted by Steve Littler on August 14, 2008 at 6:25 am
    I finished editing my movie. I took a 1.5 GB MOV file and cut out about 180 extraneous spoken words. It is about 60 minutes in length.
    Now I am trying to render a single file that I can put in Flash to put on the web.
    But when I try to render I get the following message:
    An error occurred while creating the midia file … An Error occurred writing the file. make sure you have access to the file/folder and that there is enough free space.
    I notice that it tried to write a tmp file that was HUGE (like 4 GB on one drive and then 52GB on another drive that I tried) before it crapped out.
    Can anyone suggest the best way to get a flat file out of this that I can take over into Flash?
    Many thanks!
    Steve in Alaska
    Steve Littler replied 17 years, 11 months ago 3 Members · 6 Replies
  • Jeremy Rasnic
    August 14, 2008 at 2:11 pm
    What file format are you encoding into? Try one that is compressed such as avi dv or mpg-2. Both of these should be readable by the Flash converter.
    j razz
  • Steve Littler
    August 14, 2008 at 3:40 pm
    Ahh. I had tried AVI uncompressed Default Template and MOV Default Template. I should try the AVI with the NTSC DV template?
    And then I tried to TOOLS/RENDER TO NEW TRACK. That gave me gave me 3 files of about 3.99 GB each on my hard drive but only put the first one in my Project Media bin and on the new track. Maybe I didn’t do it correctly? (I’d like to know how to do that properly.)
  • Terry Esslinger
    August 14, 2008 at 3:55 pm
    Ah, the 3.99 GB file is a clue. Sounds like your hard drive is FAT32. It should be reformatted to NTFC.
  • Steve Littler
    August 14, 2008 at 5:33 pm
    Ah, I see that you are correct. It IS FAT32. (Eyes roll)
    It’s a P4 3.066GHz CPU Win XP PRO SP2, 1.5 GB RAM, 60 GB HD. 3 years old. I wonder what would be involved to get it reformatted? Would I probably have to take it to a service shop?
    I’m still new at this video editing and learning what is really needed for proper hardware and software configuration.
    I have another external drive that is a 500 GB Seagate USB drive that is NTFS formatted. I had been using this for my video and photo files, but lately it is temperamental and will periodically lose connection with the main computer. Then I have to unplug and reboot to get the connection back. And that is bad to get interrupted in the middle of a large file operation. I’m not sure what is causing it. Maybe I should take it to a service shop as well?
    Sorry to be such a newbie. Many thanks for all your help and tips!
  • Terry Esslinger
    August 14, 2008 at 6:57 pm
    Actually, rather than a reformat you can do a conversion:
    To convert:
    “Open Command Prompt, and at the command prompt, type convert C: /FS:NTFS, where C represents the drive letter of the disk to convert. Press Enter or Return on the keyboard”
    I believe that doing this would keep you from losing all the information on the drive where a reformat is a killer. BUT I’m not sure. Maybe someone more techhie can speak up.
  • Steve Littler
    September 12, 2008 at 4:48 pm
    Thank you! Someone else also gave me this https://support.microsoft.com/kb/314097/EN-US/ and I tried it and it worked!
    Many thanks!
    Steve
