Activity › Forums › Boris FX Particle Illusion › cant render more than 344 frames
Posted by Mats Lundgren on May 12, 2009 at 11:20 amHi
I have got this problem PI stops att 344 frames and can´t render anymore…
I tried default settings, software rendering, the standalone render, but no luck…
my projecy is 500 frames, any ideas ?Mats Lundgren replied 17 years, 4 months ago 4 Members · 6 Replies -
Theo Van laar
May 14, 2009 at 10:55 amDoes the preview window still show any particle after frame 344?
Theo
Mats Lundgren
May 14, 2009 at 12:42 pmHi
Seemed to be a Videoproblem, I runned an uncompressed avi…into PI, but when I removed the BG video…it was ok…thank god for alpha 🙂 -
Alan Lorence
May 14, 2009 at 3:30 pmAs I’ve said before (several times):
Don’t use uncompressed AVI in particleIllusion (or ever really).
There’s no need for it. Ever. In any application. Use a free lossless codec like Huffyuv or Lagarith instead. You’ll have no problems in pIllusion, your files will be smaller, load faster, transfer faster, etc.
Alan.
Matt Elson
May 14, 2009 at 8:02 pmI’m having the same problem. I’ve tried loading two different Quicktime files both are compressed in h.264 and are 1280.720 pixels. Both times the playback stops roughly half way through. Solution ideas anyone?
Matt Elson
May 14, 2009 at 8:08 pmHere’s a clue, I made the clips longer and yes, they appear to be playing half of the available time. fiddling with the fields setting on import has no effect when trying to extend the clip length past half the available time. Very odd… Still looking for solution ideas… thanks!
Mats Lundgren
May 15, 2009 at 4:40 pmHi, I downloaded huffyuv and lagarith…but the playback in PI stutters with thoose codecs
