Can’t render in Vegas, ghosting / blended frames
Hi.
I’m facing a problem where video looks nice in the preview window, but when I render it, I get an awful effect were frames seem to blend on each other. It feels like they are blended as a given object is seen twice in a single frame, like ghosting.
I tried all possible render options in Vegas. I could only minimize the problem, not eliminate it. I tried upgrading from 9.0 to 9.0c, no result. I’m going crazy. I don’t know what to do any more.
There is a very strange fact too: In Vegas’ preview window, the image rendered on preview quality, auto size, looks normal. If I try to preview it in preview full, best auto, or best full, I get the problem, and it varies.
I tried all of Vegas rendering settings. For field order, progressive makes it better. Lower or upper field first make it much worser. Interleaving seems to produce no effect. I tried a few of the embedded codecs. They don’t seem to influence.
From Vegas I can take snapshots of the image previewed in different quality and size settings. They are posted here. It is weird that only preview auto looks good; Anything else does not, neither does the final rendered video. Check the rear view mirrors of the motorcycle of the white sticks in the fence in the back.
However I rendered the edited video back to the camcorder tape, played it on TV and seems like it was fine.
I’m going crazy and at the verge of quitting with videomaking. I’m struggling with this for a long time already. I don’t know if Vegas is the problem… But I could not try Adobe Premiere as it was not able to capture video from my Canon HV30 (at least in 2008 it couldn’t). Anyway this project is done and I need to publish it!
Samples:
Preview auto
https://i7.photobucket.com/albums/y286/jrkessl/2009-12-14_AjudaSonyVegas/previewautosnapshot.jpgPreview full
https://i7.photobucket.com/albums/y286/jrkessl/2009-12-14_AjudaSonyVegas/previewfullsnapshot.jpgBest auto
https://i7.photobucket.com/albums/y286/jrkessl/2009-12-14_AjudaSonyVegas/bestautosnapshot.jpgBest full
https://i7.photobucket.com/albums/y286/jrkessl/2009-12-14_AjudaSonyVegas/bestfullsnapshot.jpgRendering
https://i7.photobucket.com/albums/y286/jrkessl/2009-12-14_AjudaSonyVegas/renderAs.jpgThank you very much.
