Activity Forums Video Copilot Can’t render in the render q
  • Can’t render in the render q
    Posted by Chuck Obernesser on April 1, 2008 at 7:58 pm
    I have a project that is only ten seconds long. I want to render it out and I have rendered out many things so far with no problems. Here is the error message I am receiving:
    After effects error:unable to allocate space for a 7325×11000 image buffer.
    You may be experiencing fragmentation. In the Memory & cache Preferences dialog box, try decreasing the Maximum RAM Cache Size value and selecting the Enable Disk Cache option, increasing Maximum Memory Usage, or both.
    (7::66)
    I believe I did what it told me to but no luck. I am working on a 720×480 NTSC project. Nothing really special using some of vid copilot fx from evolution. The only thing I can think of is that I have a floor layer and I have motion tile on it. It’s set to horz. around 500 and vert. 500. Could that be it?
    Thanks for any and all help, I really don’t want to start over.
    Chuck
    Obernesser Productions
    http://www.obernesserproductions.com
    Chuck Obernesser replied 18 years, 5 months ago 2 Members · 2 Replies
  • Jason Jenkins
    April 1, 2008 at 8:25 pm
    Try going to Edit> Purge> All. See if that helps.
  • Chuck Obernesser
    April 1, 2008 at 8:38 pm
    Jason,
    I did that and I adjusted the motion tile. I think between the both of them it helped out cause it still take a few sec to render but not as bad as before.
    Thanks a lot!
    Chuck
