Activity Forums Adobe After Effects Can’t render as jpeg sequence in Adobe Media Encoder
  • Can’t render as jpeg sequence in Adobe Media Encoder
    Posted by Marek Connell on January 12, 2013 at 5:19 pm
    I have a problem.
    I want to render an after effects scene (no video assets just shapes, illustrator images etc) using the adobe media encoder.
    I want to render as jpeg sequence in but I can’t apply this setting for some strange reason. If I choose other formats like vimeo youtube etc I can select them but not any of the image sequence options.
    Why is this?
    I can do it in AE but not in the media encoder.
    Please advise. Is there a possible workaround?
    Warm regards
    Marek
    Igor Shipilov replied 3 years, 12 months ago 6 Members · 8 Replies
  • 8 Replies
  • Tero Ahlfors
    January 12, 2013 at 6:15 pm
    Choose JPEG as the format, set up the frame rate and resolution and remember to check that export as sequence-tab is checked.
  • Marek Connell
    January 12, 2013 at 11:20 pm
    Hey Tero,
    I’m afraid it’s not that simple in my case.
    I simply can’t select the image Jpeg sequence option. It is greyed out for any of the image sequence render methods. Other methods eg HD work fine.
    Yet in AE it works fine.
    I just don’t understand.
  • Roland R. kahlenberg
    January 13, 2013 at 4:04 am
    A JPG image sequence is a very uncommon format to use. Is there a good reason why you’re rendering to this format? Most folks use TIFF or DPX sequences for production work. For previews, stick with a H.264 version.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects ACE/ACI (version 7)
  • Tero Ahlfors
    January 13, 2013 at 8:54 am
    I don’t see where it’s grayed out. Open the file settings in the render queue and choose JPEG under the format drop down menu or drag the preset from the preset list you have open on your images.
  • Marek Connell
    January 13, 2013 at 1:33 pm
    Tero,
    This is what I mean. (See attached image)
    Apart from this column I cannot select jpeg sequence anywhere else in Adobe Media Encoder.
  • Robert Williams
    February 8, 2013 at 10:03 pm
  • Andreas Fiske
    June 13, 2013 at 2:29 pm
    I had the exact same problem.
    Thank you Robert Williams for your solution.
    It workes perfectly now!
  • Igor Shipilov
    September 23, 2022 at 10:32 pm
    I have faced with this issue toda: Media Encoder just stopped seeing JPEG sequences. I solved this problem by resetting it to default settings: holding Shift while Media Encoder running, until it opens.
    So holding “Shift” key while you on this screen:
