Activity Forums VEGAS Pro Can’t render any format in Sony Vegas Pro 9
  • Can’t render any format in Sony Vegas Pro 9
    Posted by Carol Oates on June 10, 2009 at 12:55 am
    Greeting from Ireland. I have spent days editing clips in Pro 9 and rendered it at stages to see how it was comming along. I even rendered the full 4 and a half minutes today in mp4 with no problem. When I went back to it tonight, first it was giving error 5 and I noted a mention of MP4, but I’m not tech minded so I didn’t read too carefully. After reading through a lot of threads I discovered ticking 2 passes on mp4 in pro 9 causes it to crash. So I unticked 2 passes, now it looks like its rendering but the progress isn’t moving and the time keeps rising. I reinstalled but that didn’t help and I haven’t added anything to the timeline since it rendered perfectly earlier today so I’m at a loss. Any ideas? I really don’t want to see all that work go to waste.
    Manuel Samaniego replied 15 years, 2 months ago 4 Members · 3 Replies
  • Mary Waitrovich
    June 11, 2009 at 6:13 pm
    I had trouble rendering .mov (only)files after Vegas 9 Pro install. My problem turned out to be related to the hard drive I was working on. If you have more than one hard drive available, it might at least help your trouble shooting if you try rendering to a different drive.
    Good luck,
    Mary Waitrovich
    UW-Madison
  • Aton Bonba
    July 11, 2009 at 4:08 am
    if it freezes at 0% and the loading time keeps go up the problem is with the audio tracks, i had 2 audio track, one is the background noise of the video, the second one is the music! i deleted the background noise and it renderred succesful so i dont know exactly what, but the problem is with the multiple tracks’ interference for me
  • Manuel Samaniego
    June 22, 2011 at 11:25 pm
    Hello Aton Bonba, thankyou very much for the info, i had this same problem but i fixed with what you said
    Thanks a lot mate!
