Activity Forums VEGAS Pro Can’t Render a Blu-ray Image file (iso) to burn BD
  • Can’t Render a Blu-ray Image file (iso) to burn BD
    Posted by Rick Braden on March 9, 2008 at 4:36 pm
    Had Vegas Pro 8 for a week & following tutorial on Sony website to burn a BD from the timeline. I am using a 90 second test footage from Sony EX1 in HQ mode, (35Mbps, 1920×1080, 24p). Once I have it in the time line I go
    Tools-Burn Disc-Blu ray Disc-Render image & burn.
    Video format: MainConcept MPEG-2(*.mpg;#.m2v:*.m2t;*.mpa)
    Video template: Blu-ray 1920×1080-24p, 25 Mbps video stream
    Audio format: Sony Wave64(*.w64)
    Audio template: 48,000hz, 16 Bit, Stereo, PCM
    Image parameter-File path: F:\vegas BD Images\Bigguys24p.iso
    Burn drive is set to my BD drive.
    When I hit OK it shows that it Renders from 0% & goes up to 100%.
    Then at 100% I get “An Error Occured Preparing the Image”
    When I hit “Details” this is what it says
    Filename: STREAM/00001.m2ts
    Status: TSWrapper.dll::CTSWrapper::ProcThreadMain::IO Error — Failed to open file: ‘D:\Vegas Temp Files Folder\~bdmux3396\media\Bigguys24p.w64.ves’ –
    I saved my project as Bigguys24p. I did what the VASST #1 Vegas tutorial recommends about moving the temp folder off C: drive & I moved it to Drive D & named it Vegas Temp Files Folder.
    I’m sure it’s something I’ve overlooked. Any help would be appreciated. Thanks very much.
    RickyB
    Rick Braden replied 18 years, 6 months ago 2 Members · 2 Replies
  • Edward Troxel
    March 9, 2008 at 6:39 pm
    Try changing the audio format to AC3 instead.
    Edward Troxel
    JETDV Scripts
  • Rick Braden
    March 13, 2008 at 8:06 am
    Edward,
    Thank you for the advice. I used the ac-3 & it worked fine. I have to learn more about the wav64 & why it didn’t work.
    RickyB
