Activity Forums Boris FX Particle Illusion Can’t render
  • Posted by Steve Stryker on April 13, 2009 at 2:03 am
    Trying to render an AVI file with no background just the particle.
    Every time I go into render in stand alone or launched via pi it crashes. I get “the program has stopped working”
    This is in the details:
    Problem Event Name: APPCRASH
    Application Name: pIllusionRender.exe
    Application Version: 3.0.7.0
    Application Timestamp: 495ab534
    Fault Module Name: pIllusionRender.exe
    Fault Module Version: 3.0.7.0
    Fault Module Timestamp: 495ab534
    Exception Code: c0000005
    Exception Offset: 00006ce5
    OS Version: 6.0.6001.2.1.0.256.1
    Locale ID: 1033
    Additional Information 1: fd05
    Additional Information 2: 099e53a62bee4ee6974d329646e92107
    Additional Information 3: 6bfe
    Additional Information 4: 955083987b8d487b4e61d6bf1070c66e
    Anyone help?
    Sony Vegas, Particle Illusion, NOOB!
    Bob Williamson replied 17 years, 4 months ago 3 Members · 3 Replies
  • Steve Stryker
    April 13, 2009 at 2:04 am
    Oh and I am using latest version.
  • Alan Lorence
    April 13, 2009 at 3:30 pm
    Try switching pIRender to use software rendering. Run pIRender, click the Options button, then uncheck the hardware acceleration button.
    If this works, then you should check if there are updated video drivers for your card.
    Alan.
    http://www.wondertouch.com
  • Bob Williamson
    April 25, 2009 at 7:51 pm
    For what it is worth … I had a similar problem recently. I could not render to any “single image format” (i.e. jpeg, png). This was true even when using the software renderer. I re-installed the latest software patch (#3041) and the problem was resolved. The cause of the issue was unknown, but I chalk it up to Vista.
