Activity Forums Adobe After Effects Can’t Render 4k Red footage with Timewarp effect applied
  • Can’t Render 4k Red footage with Timewarp effect applied
    Posted by Scott Clements on May 19, 2015 at 5:49 pm
    I’m having problems rendering a 4K Red clip with a Timwarp Effect applied with the following settings:
    Pixel Motion
    50%
    Vector Detail 100%
    Block Size 10
    Motion Blur: 180 degree shutter – 5 Shutter samples
    When I go to render, I can render at half resolution, but not at 4K.
    I get a render error that says” Unable to allocate enough memory to render the current frame (3840 x 2160 @32 bpc). Either decrease the memory requirements for the rendering of this frame or install more ram. (12805)”
    I’m not very knowledgeable about processors and memory and such. I’m on a mid 2014 macbook Pro retina 2.8 GHz – 16 gigs of Ram. I’m not sure why I can’t render this shot. I would set vector detail lower, but unfortunately,I feel I need it in order for the shot to look half decent.
    Film Editor, London UK
    http://www.scottclementseditor.com
    Members
    Scott Clements replied 11 years, 4 months ago 2 Members · 5 Replies
  • Scott Clements
    May 19, 2015 at 8:06 pm
    Thanks, Dave. Unfortunately, I already had multiprocessing off.
  • Michael Szalapski
    May 19, 2015 at 8:28 pm
    What are your memory and multiprocessing settings?
    What, exact, version of AE are you using down to the last decimal?
    What are your render settings and output settings in the render queue?
    (Screenshots would probably be easiest.)
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Scott Clements
    May 19, 2015 at 9:17 pm
  • Michael Szalapski
    May 19, 2015 at 9:57 pm
    If you turn off the Timewarp effect, does it render?
    How far into the render does it go before you get the error?
    It might behoove you to go into the “secret” preferences and have it purge every few frames. (Hold shift while navigating to and opening the preferences.)
    – The Great Szalam
  • Scott Clements
    May 19, 2015 at 10:01 pm
    Hi, Michael.
    If I turn off timewarp, it renders. I can render half resolution in the render que settings with timewarp on. It renders 1 or 2 frames before the error comes up…sometimes it doesn’t even get to one frame though. I didn’t know about the purging or secret settings. I will look into that. Thanks.
