Activity › Forums › Apple Final Cut Pro Legacy › Can’t render
  • Posted by Kenny Powerass on July 28, 2005 at 2:05 pm
    I can’t render.
    You know the flash of the render window you see when you tell your sequence to render and it’s already rendered? That’s what I see when I tell it to render. Problem is I’m not rendered.
    I tried selecting an unrendered portion and hitting ‘render selection’…nothing.
    I tried command-R…nothing.
    I tried render only…nothing.
    I recently had to trash my preferences and I changed my scratch disk at the same time (not to a new drive, but to my usual drive). Did I screw something up when I did that?
    Kenny
    Dual 2G G5
    OS 10.3.9
    2G RAM
    Kenny Powerass replied 21 years, 2 months ago 3 Members · 5 Replies
  • Walter Biscardi
    July 28, 2005 at 2:37 pm
    [Kenny Powerass] “I recently had to trash my preferences and I changed my scratch disk at the same time (not to a new drive, but to my usual drive). Did I screw something up when I did that?”
    Yep. You need to re-set all your Render Prefs. Go to Sequence > Render All (and Render Selection). You need to reset those parameters.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Kenny Powerass
    July 28, 2005 at 2:48 pm
    I’m not sure how to reset the parameters. I’ve gone to the render menu and unchecked and rechecked everything that’s checkable. I’m not sure what else i can do there.
  • Bouncing Account needs new email address
    July 28, 2005 at 4:58 pm
    Try trashing your Preferences AGAIN (then “re-Checkmark” all of the Render selections) and see if that bring you back to life.
  • Kenny Powerass
    July 29, 2005 at 5:08 am
    That did the trick.
    Kenny
  • Kenny Powerass
    July 31, 2005 at 5:41 am
    24 hours later it happened again. And again, trashing prefs fixed it…but this is getting old quick.
