Activity Forums VEGAS Pro Can’t remove letterboxing?
  • Can’t remove letterboxing?
    Posted by Angelo Mike on March 4, 2012 at 7:06 pm
    I’m trying to edit a video from Youtube that has audio that’s not in synch with the video (for my personal viewing), and am trying to render it, but I can’t get rid of the letterboxing that Vegas creates with the project. I matched the project settings to that of the video-480×360, PAR of 1.0, progressive scan, and 29.999 fps.
    Here is a link to the original video (with no letterboxing).
    https://www.youtube.com/watch?v=3pzBMrPVZv4
    Here’s how it appears in my Vegas project.
    Full screen in my project.
    And trying to correct it by setting the aspect ratio to 16×9 in the pan and crop function-which normally works, but here, does nothing to change the size of the image or to remove the letterboxing (yes, I realize that it’s keyframed to that one position, but I had it set to 16×9 for the entire video and at no point does it actually make the video 16×9 or remove the letterboxing).
    Finally, here’s a test upload I did.
    https://www.youtube.com/watch?v=80oMOSKKQI4
    Basically, it seems that no matter what, I have a 4:3 image that’s letterboxed. Any ideas?
    http://www.scenethroughglass.com
    John Bean replied 14 years, 6 months ago 3 Members · 3 Replies
  • Angelo Mike
    March 4, 2012 at 7:14 pm
    I just found the answer and got it working, but I want to leave this post up to be a lesson to everyone-sometimes just laying out, step by step, what you’ve done, so that you can hear/read yourself doing it, is enough to find your mistake.
    What I was missing was that I’m not supposed to changed the aspect ratio in the project. You have to remove letterboxing in a situation like this in the render, by rendering to widescreen. Duh.
    It’s still not quite perfect, though, so I’m wondering if I’m missing anything else. I rendered to 640×360 widescreen, PAR of 1, as mp4, with small black bars along the top, bottom, and sides. Here it is.
    https://www.youtube.com/watch?v=wByVOO49gQ0
  • Matt Crowley
    March 5, 2012 at 8:15 pm
    For something like this, you should be setting your project settings to match the desired output format (eg 640×360), then dropping your 4:3 footage on the timeline and cropping the video event with the crop aspect set to “Match output aspect”. Crop the 4:3 event so that you just get rid of the letterboxing, then render with the same frame format (eg Internet 360p).
  • John Bean
    March 6, 2012 at 7:04 am
    That YouTube video already has top and bottom BLACK BARS.
    It looks like the person who uploaded it, simply captured it from their standard-definition cable-tv signal and uploaded it to YouTube without cropping the BLACK BARS out.
    The actual video – without the black bars – is suppose to be widescreen 16:9. Given that the video frame size is 480×360 with black bars, that would mean the actual video (without the black bars) is just 480×270.
    So you need to change your project settings. Personally, I’d go with a more standard frame size for 16:9 like 640×360.
    So your PROJECT SETTINGS should be:
    1. FRAME SIZE = 640×360
    2. PAR = SQUARE
    3. SCAN-TYPE = None (Progressive)
    4. FRAME RATE = 30
    After importing the video, then use the PAN/CROP tool. Simply select the preset for 16:9.
    That is it! No more black bars!
