Activity › Forums › Avid Media Composer › Cant relink media files
  • Cant relink media files
    Posted by Omer Ozcan on November 30, 2010 at 5:13 pm
    Hello,
    I am quite new to avid.
    we recently shoot something and made some editing in a professional post-pro company. afterthan i took all project with an external drive.
    now it seems all media files are offline and when i try to relink them it says no clips were relinked.
    i searched on internet for solutions, i tried to delete mdb and pmr files and re-opened project but avid didnt do any scanning.
    it seems avid still thinks those media files are on a drive named as F but they are not.
    any suggestion to relink them?
    thank you.
    Aza Allen replied 15 years, 6 months ago 3 Members · 4 Replies
  • Michael Hancock
    November 30, 2010 at 5:47 pm
    The media must be in a certain file structure on the root of your drive. For example, if the media is now on the M: drive, it should be here:
    M:\Avid MediaFiles\MXF\1\[MEDIA – .mxf files – goes here]
    If your folder structure is any different, or spelled any differently, Avid won’t see it as media and won’t scan and database it.
    Michael Hancock
    http://www.oswaldcommunications.com
  • Omer Ozcan
    December 1, 2010 at 9:23 am
    there was no MEDIA file, it was like AvidMediaFiles\MXF\1 .mxf files. so i create a new file as MEDIA and move all mxf files into it but it didnt work.(no scanning)
    i have three files in my disc; Avid MediaFiles – project file(statistics,bins etc.) – OMFI Mediafiles. nothing seems missing but it still thinks all files in another drive.
    am i doing something wrong?
    thank you in advance Michael.
  • Michael Hancock
    December 1, 2010 at 3:45 pm
    I think you misread what I typed (and what I typed wasn’t very clear). You shouldn’t have a MEDIA folder inside your numbered folder – I was saying that’s where you media goes. Sorry about the confusion.
    You should have:
    M:\Avid MediaFiles\MXF\1\.mxf files
    M:\OMFI MediaFiles\.omf media
    Your project file (you can put this where ever you want).
    If you don’t have a space between the words “Avid” and “MediaFiles”, Avid won’t see your media. So if it’s AvidMediaFiles -> Media will be offline. If you have your .mxf files inside a MEDIA folder inside your numbered folders, Avid won’t see your media.
    Also, when you open Avid go to your Media Creation settings and make sure Filter Drives Based on Resolution is unchecked, and uncheck Filter System Drive and Filter Launch Drive. Then try to rescan your databases (File–>Reload Media Databases). That should force a rescan, or close Avid, delete the database files, then relaunch Avid.
    Michael Hancock
  • Aza Allen
    March 17, 2011 at 9:51 am
    I am having the same issue…
    My boss backed up a bunch of drives that we needed to clear up room on, so He copied all the various OMFI Mediafiles folders for the various projects into folders on an external drive.
    Now I am trying to get Avid to link to those files so I can consolidate them on another drive. I move the “OMFI Mediafiles” folders into the root of my external drive, then I open the corresponding project in Avid (which is located on a different drive) and I try to relink them in Avid, but it won’t relink. I’ve tried deleting ALL the database files, it still won’t scan the external drive.
    I have no idea how to get Avid to scan my drive. I know Avid can see the drive because I try creating a blank title into it, and it shows up as a drive to save to. DOesn anyone have any ideas?
    it’s MC 2.6.4, just in case.
    Thanks all!
    Make sure to check out our website http://www.makeyourfriendsuncomfortable.com and my personal website http://www.ruesterprod.com
