Activity Forums Adobe Premiere Pro Can’t reinstall Premiere Pro
  • Can’t reinstall Premiere Pro
    Posted by Jamie Burkhardt on August 3, 2006 at 1:44 am
    Hey Guys,
    Recently I was having a problem with premiere pro 2.0 so I tried to uninstall so that I could install it fresh. However when I go to remove it from Add/Remove programs, it says that the uninstall process was interrupted and cannot continue. So I tried manually removing it. I deleted the Adobe folder, the Adobe and Adobe System shared subfolders from the Common files folder, and went into the registry to delete any keys dealing with premiere and adobe.
    However, after rebooting and trying to install Premiere, the install wizard never gives me the option to install. It only gives me Repair and Remove. I thought maybe there was a virus somewhere but I have cleaned all spyware off my computer using three different spyware and virus programs. I also cleaned out my registry with Reg Mechanic. Still the same problem continues. Can there still be some files leftover somewhere that I haven’t deleted? I went through the registry a thousand times.
    Any help would be appreciated.
    Jamie
    Aanarav Sareen replied 20 years, 1 month ago 3 Members · 2 Replies
