Activity › Forums › Panasonic Cameras › can’t record directly to hard drive
  • can’t record directly to hard drive
    Posted by Matt Schulze on February 25, 2009 at 12:08 am
    I’m trying to hook up my HVX200 directly to my powerbook G4 1.67 gig running FCP 6.0.5 using the firewire connection to record directly to my powerbook’s hard drive.
    I can see the image from the camera in the log and capture window. I can see time code (time of day) in the log and capture window if I set the camera to free run. I can hit capture now and it will record but only about 36 frames and then it tells me that it reached the end of the tape.
    I’m not using tape, why does it give me this error? What setting am I missing?
    Capture settings are set to 720p60 and DVCPRO HD
    I am outputting from the “over 60 mode”.
    It looks like I have everything ready to go except I only get one second of recording.
    Matt
    Matt Schulze replied 17 years, 7 months ago 3 Members · 4 Replies
  • Steve Eisen
    February 25, 2009 at 3:28 am
    You are going to need Adobe On Location (CS4) to record in HD via firewire.
    You can only record DV25 via firewire in FCP.
    If you want to record HD directly to hard drive in FCP, you will need the AJA IO HD (Pro Res) or Matrox MXO2.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Jeremy Garchow
    February 25, 2009 at 6:10 pm
    Not necessaily, you can do this with FCP via firewire in DVCPro HD, but you will lose all timecode. You need to set FCP to ‘non-controllable device’ to get it to work.
    Jeremy
  • Steve Eisen
    February 25, 2009 at 8:37 pm
    Matt
    720p60 and 1080i60 captures on my FCP system using non-controllable device.
    Steve Eisen
    Board of Directors
  • Matt Schulze
    February 26, 2009 at 6:34 am
    Thanks guys,
    that worked and you don’t even have to press record on the camera.
    It’s true that there is no timecode pass through, but that may not be important in all situations. Would be nice if it did record the timecode though.
    Matt
