Can’t Reconnect Media
Hi all,
Recently, my mac’s internal hard-drive crashed and nothing was recovered. Luckily, most things were backed up, but FCP is giving me a really hard time about reconnecting the media for a few sequences for some reason.
The 5 video files I want to reconnect are exactly the same length as the ones that are missing, and are the same footage. When I try to reconnect them when FCP starts up, I get the message:
“Some attributes of one or more of the files you have chosen do not match the attributes of the original. This may cause problems within the sequences that are dependent on them. The attributes that differed are as follows: -Media Start and End.” If I try to connect them it gives me a host of errors.
If I try to connect the media in FCP, it just says: “Offline Files: [The Drive]:” — and blank. Nothing to reconnect. This happens even if I cancel the option to reconnect when I start.
The only other things I can think to note are:
— the ones that won’t reconnect had all been renamed in the project file (e.g. “Ryan_talk_1”) and the files I’m trying to hook up are all “Untitled1” etc.
— when I try to reconstruct the missing scenes from the time data in the disconnected media files, they all seem to be slightly off, i.e. half a second. Not sure if this indicates anything.Any thoughts, please let me know. Is there any way to ‘force’ Final Cut to accept media? Driving me crazy having to stitch together disconnected media scenes right in front of me from a file the exact same length with all the same stop and starts as what’s missing!
Thank you.
-Jeff
