Activity Forums VEGAS Pro Can’t put effect on edited video?
  • Can’t put effect on edited video?
    Posted by Seb Scherwat zingmark on May 24, 2016 at 10:49 pm
    Hi! I have been struggeling to understand what I’m doing wrong in Sony Vegas 13. I’m trying to put an effect on a short video but at first I couldnt do it. It was a simple Defocus effect. I then tried to put the effect on the clip without cutting the video, and for some reason it worked just fine when I did that.
    But I want to cut my video, then put on the defocus effect. It’s suppose to “blur out” and I used the time line correct, since it worked with the uncut version of the video.
    So why can’t I use the effect on the cutted version of the video? Any ideas?
    Wayne Waag replied 10 years, 4 months ago 2 Members · 1 Reply
  • Wayne Waag
    May 25, 2016 at 12:56 am
    Lots of ways to do this.
    You can first apply the effect to the uncut version. If you then do cuts, the effect will remain applied to the cut events.
    Or, you can do your cuts editing first. Apply the effect to the first event. Then copy that event (ctr-c). Go to the next event, right click and select all events to the end. Then select Paste Event Attributes. That effect will be applied to all events selected.
    Or, if you want to apply that effect to the entire clip, you can apply it as a media FX rather than an event FX. Select the clip in the project media window, right click and select Media FX. Then apply your effect. It will be applied regardless of any cuts on the timeline.
    wwaag
