Activity › Forums › Adobe Premiere Pro › Can’t produce an AVI file
Posted by Joe Landau on October 16, 2006 at 1:14 pmUsing Premiere Pro I export a 75 min. video to a movie. It goes on for several hours and just before the end it aborts. I get an unreadable AVI file with a size of 99% of what it should be. What is wrong?
Thx,
JoeJoe Landau replied 19 years, 11 months ago 3 Members · 4 Replies -
Mike Velte
October 16, 2006 at 2:12 pmWhat version of Premiere?
Any error message?
How much space on each hard drive?
What are your export settings? -
Joe Landau
October 16, 2006 at 2:27 pmThx 4 response.
I need the video to have a 16:9 aspect ration since that’s what I shoot with
PP ver. 7.0
No error msg
Free space 150 GB each on C & D Drives (Project file on C, assets on D)
Settings:
File Type: Microsoft DV AVI
Export Video – Checked
Export Audio – Checked
Add to Project when Finished – Checked
Embedding Options – None
Compressor – DV(NTSC)
Color Depth – Millions of Colors
Aspect Ratio – D1/DV NTSC Widescreen 16:9 (1.2)
Quality – Grayed out
Data Rate – Limit to Rate – Unchecked
Recompress – Checked Maintain Data Rate
Keyframe and Rendering Fields – Lower Field First
Optimize stills – Checked
Keyframe options – None checked
Audio
Compressor – – Uncompressed
Sample Rate 48000 Hz
Sample Type 160nit
Channales – Stereo
Interleave – 1 Frame -
Tclark
October 16, 2006 at 3:14 pmCheck to see if you have any effects on clips near the end of your timeline. Some effects like auto color correct or any of the auto color correction effects can cause this if there is extreme lighting changes on that particular clip.
Joe Landau
October 16, 2006 at 9:27 pmI took off the tail end of the video (about a minute worth) with the intention of rendering it separatly and combining with the rest of the video. However, Premiere failed again, this time with an error message –
________________________________________________________________
The instruction at “0x1064b610” referenced memory at “0x0000000b”. The memory could not be “read”.Click OK to terminate the program
I am still baffled
