Activity › Forums › Apple Final Cut Pro Legacy › Can’t Print to Video
Posted by Buglight on September 1, 2005 at 9:12 pmI cannot print to video since upgrading to FCP 5.0.2. When I try to print to video I do not get video or audio to my deck (DSR-45).
If I scrub through the timeline I can see updated video on the deck but when I hit play the video freezes I do however get audio. I’ve changed cables, checked and rechecked settings (external video all frames, Playback – Apple Firewire NTSC, Audio follows video etc.)
Here’s my config:
OSX 10.3.9 -Quicktime 7
Dual 2.5 G5, 4GB Ram
DSR 45 connected to the rear native FW400
Firewire 800 Drive on it’s own PYRO FW800 cardBuglight replied 21 years ago 3 Members · 3 Replies -
Bouncing Account needs new email address
September 1, 2005 at 9:23 pmFirst thing to always try is to Quit FCP, Restart the Mac, Open your FCP project and try again.
Next:
THE FOLLOWING COMES FROM THE KEN STONE WEBSITE:
“Over 5,000 years ago Confucius wrote: ‘If you are toiling away, you have changed nothing and FCP heads South on you, [starts behaving in strange ways] then it is time to trash your FCP Preferences.’ ”Click the following link for instructions.
https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
A great way to do this is to use “FCP Rescue” a free Apple Script that will Trash the Preferences for you (and restore nearly all of your user settings afterward).
There are versions for FCPro & FCExpress.Download these free Apple Scripts at
https://fcprescue.andersholck.com/
Rob Forsythe
September 1, 2005 at 9:24 pmThis list contains about everything to try to enable:
a. External Monitor VIDEO and AUDIO via FireWire & DV deck or camcorder.
b. Viewing in the Canvas window on the computer screen.
c. Being able to record on the external FW DV deck or camcorder.Try things in this order until you find the “cure”:
1. Make sure you have only ONE (1) FireWire deck, camcorder, DV capture “card”, or D-to-A converter or video device attached to the computer at a time. Any more than one DV device can cause loss of signal and control.
2. Make sure you have View (Menu) > External Video> All Frames set.
(If the ALL FRAMES option is grayed-out… jump to step 6 below and continue.)
3. Make SURE your Canvas window (right window) in FCP is set to “Fit to Window”… AND that it has not been “pushed off” the edge of the computer screen.
4. Make sure your CANVAS View Menu (Box Icon with broken sides) is checked on Image or Image+Wireframe… NOT just Wireframe.
5. Make sure your CANVAS View Menu is checked on RGB… NOT just Alpha.
6. Make sure your Final Cut Pro (menu) > Easy Setup… is set for DV-NTSC (or DV-PAL, if that’s where you are).
7. Some camcorders/decks work better under “FW (NTSC/PAL)” -or- “FW (NTSC/PAL) Basic” control (in the capture settings). Try either setting to see which works best for your device.
8. Make sure your Final Cut Pro (menu) > Audio/Video Settings > A/V Devices (tab) > Mirror on Desktop > must be CHECKED. (If not, playing video will not appear in the Canvas.)
9. Make sure the “Log and Capture” Window is CLOSED and not just “hidden” behind other windows.
10. Turn off the power to the Camera/Deck/Converter Box, then turn it back ON.
11. Make sure the camera is in VTR mode… or the deck is in DV (DV, iLink, or FW) input.
12. On a Sony camcorder or deck, make sure the menu setting “A/V > DV Out” is set to OFF.
13. Re-check that your FW cable is well-connected at both ends (or try a new cable).
14. Important: Quit FCP, then Restart FCP.
15. Now again, make sure you have View > External Video > ALL FRAMES set…And if these don’t help check here:
https://docs.info.apple.com/article.html?artnum=301852
Buglight
September 1, 2005 at 9:41 pm[Rob Forsythe] “8. Make sure your Final Cut Pro (menu) > Audio/Video Settings > A/V Devices (tab) > Mirror on Desktop > must be CHECKED. (If not, playing video will not appear in the Canvas.) “
This was the problem! I had “Different Output for Edit to Tape/Print to Video” unchecked. As soon as I saw it I knew that was the problem. Just tried print to video and it worked like a charm. Thanks for your help.
-keith
