Activity Forums Apple Final Cut Pro Legacy can’t print to tape
  • can’t print to tape
    Posted by Barry Davis on May 31, 2005 at 8:46 pm
    I haven’t used my G4 with FCP in a while. I now have a problem where the video going outbound freezes during the playback of my rendered timeline. This problem exists with my DataVideo DV converter as well as plugged directly into a Sony Dig8 Camcorder. I never had this problem until just now. I have plenty of hard drive space. I’ve tried re-digitizing the clips I’m using today.
    I’ve tried to print to tape previously edited and printed to tape projects with the same results.
    Barry Davis replied 21 years, 1 month ago 3 Members · 4 Replies
  • Shane Ross
    May 31, 2005 at 9:38 pm
    Go to the VIEW menu and select EXTERNAL>ALL FRAMES.
  • Rob Forsythe
    May 31, 2005 at 9:42 pm
    This list contains about everything to try to enable:
    a. External Monitor VIDEO and AUDIO via FireWire
    b. Viewing in the Canvas window on the computer screen
    c. Being able to record on the external FW DV deck or camcorder..
    Try things in this order until you find the “cure”:
    1. Make sure you have only ONE FireWire deck, camcorder, or DV capture “card” attached to the computer at a time. Any more than one DV device can cause loss of signal and control.
    2. Make sure you have View (Menu) > External Video> All Frames set.
    (If the ALL FRAMES option is grayed-out… jump to step 6 below and continue.)
    3. Make SURE your Canvas window (right window) in FCP is set to “Fit to Window”… AND that it has not been “pushed off” the edge of the computer screen.
    4. Make sure your CANVAS View Menu (Box Icon with broken sides) is checked on Image or Image+Wireframe… NOT just Wireframe.
    5. Make sure your CANVAS View Menu is checked on RGB… NOT just Alpha.
    6. Make sure your Final Cut Pro (menu) > Easy Setup… is set for DV-NTSC (or DV-PAL, if that’s where you are).
    7. Some camcorders/decks work better under “FW (NTSC/PAL)” -or- “FW (NTSC/PAL) Basic” control (in the capture settings). Try either setting to see which works best for your device.
    8. Make sure your Final Cut Pro (menu) > Audio/Video Settings > A/V Devices (tab) > Mirror on Desktop > must be CHECKED. (If not, playing video will not appear in the Canvas.)
    9. Make sure the “Log and Capture” Window is CLOSED and not just “hidden” behind other windows.
    10. Turn off the power to the Camera/Deck/Converter Box, then turn it back ON.
    11. Make sure the camera is in VTR mode… or the deck is in DV (DV, iLink, or FW) input.
    12. On a Sony camcorder or deck, make sure the menu setting “A/V > DV Out” is set to OFF.
    13. Re-check that your FW cable is well-connected at both ends (or try a new cable).
    14. Important: Quit FCP, then Restart FCP.
    15. Now again, make sure you have View > External Video > ALL FRAMES set…
    If it still does not work. “Trash” the FCP Preferences on the Mac
    https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
    “FCP Rescue” is a free Apple Script that will Trash the Preferences.
    It will also restore your user settings afterwards.
    Download:
    https://www.macupdate.com/info.php/id/14729
    >Then, start again at my “step 1” above.
  • Barry Davis
    Thats not the problem….I can change that…itys when the time line is moving and the video is going tothe recording device, either directly thru firewire to my Sony Dig 8 camcorder(that I have used for countless videos), or thru an interface that I have used countless times. The video freezes on the first frame after I play the time line. Then after hitting the pause button, the video changes to the frame the timeline stopped at.
  • Barry Davis
    May 31, 2005 at 10:15 pm
    Rob, thanks….everything was n order, but the machine returned to normal…I’ll keep your list handy, but I went through all those items prior to loging on here….
