Activity › Forums › Avid Media Composer › cant print tape
  • cant print tape
    Posted by Rap on May 20, 2007 at 4:44 pm
    hey guys I am running xpress pro 4.6 without the mojo and I’m trying to print atape but am bot getting a signal to the deck unless i do digital cut, and when i do so and after running 48 minutes of the film it always stops at the same point with the message of “video underrun”, this is driving me crazy
    I dont understand why am I not getting a signal to the deck!
    why is the quality button appears onlt green/ yellow or yellow/ yellow? why cant i get green/ green?
    I tried mixing down the video but it still stops at the same point
    please advise me
    what should i do ? I need to get this tape out ASAP
    Bill Stephan replied 19 years, 4 months ago 2 Members · 1 Reply
  • Bill Stephan
    May 21, 2007 at 3:32 pm
    A video underrun means the hard drive storage is not running fast enough to supply video & audio data to the output.
    Make sure that you close all bins except the one with the sequence. Also close all tools (effects, mixers, eq, etc). All these things eat CPU resources when they are open.
    If all else fails, you will need to output your project in smaller segments.
    Bill Stephan
    Senior Editor/DVD Author
    USA Studios
    New York City
