Activity Forums Apple Final Cut Pro Legacy can’t preview mpeg2 clip in fcp 7
  • can’t preview mpeg2 clip in fcp 7
    Posted by Graeme Benson on November 11, 2009 at 9:01 pm
    Can anyone tell me if there is any way round previewing mpeg2 in fcp7
    I have a sony hvrz7. It records compact flash files using the mpeg2 stream.
    the log and transfer window will import the WHOLE file. But I only want to select rather than ingest the whole large file onto my ext media drive
    So if anyone out there can advise, this would be much appreciated
    Do I need to convert to anything?
    Cheers
    Graeme Benson
    Aaron Neitz replied 16 years, 9 months ago 2 Members · 3 Replies
  • Aaron Neitz
    November 11, 2009 at 9:14 pm
    In log/transfer you can watch your footage in the preview window, and then you can set an IN/OUT. it will only convert that little bit for you.
  • Graeme Benson
    November 12, 2009 at 9:10 am
    In FCP7, the preview window reads the following message
    PREVIEW DOES NOT RECOGNIZE THIS FORMAT
    (i.e. HDV mpeg2 COMING FROM MY CAMCORDER HDV Z7)
    So I cannot set In and Out points because it won’t let me preview: it’s greyed out
    So any way round this?
  • Aaron Neitz
    November 12, 2009 at 8:40 pm
    Sorry Graeme, i’m zero on ideas here – haven’t worked with HDV before. Is it a tape based camcorder?
