Activity Forums Avid Media Composer Can’t play clips in project window
  • Can’t play clips in project window
    Posted by Joshua Moise on January 9, 2006 at 1:52 am
    When I tried to play my project “DISK_FILE_NOT_FOUND” appears in the bottom left hand corner of the project window. My clips are fine in my Avid media folder and play OK in the source window.
    Should I delete the msmFMID or the msmMMOB database files? If so, which ones?
    Thanks a lot for the help.
    Zatoichi
    Joshua Moise replied 20 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
