Activity › Forums › Apple Final Cut Pro Legacy › Can’t Play back Audio in FCP
Posted by Luis Guerrero on October 9, 2005 at 7:02 pmI don’t know what I just did but I can’t playback the audio on any clip that I have. I have even opened up older finished projects.
Does anyone have an idea what I could have done. Everything had been working perfectly.
-Luis Guerrero
Rob Forsythe replied 20 years, 11 months ago 3 Members · 2 Replies -
Debe
October 9, 2005 at 7:15 pmAre you monitoring externally or internally?
Can you see the audio meters running and can’t hear it, or there’s nothing on the meters?
Have you trashed preferences and repaired permissions lately?
Repairing permissions is done in Disk Utility usually located in [main hard drive]>Applications>Utilities.
For info on trashing prefs, look at here…
https://www.lafcpug.org/trashing_fcp_prefs.html
The following is a nifty little program that stores and trashes prefs for you. Just be careful backing up the first time. Make sure you’re backing up clean prefs.
https://fcprescue.andersholck.com/
If this doesn’t help, post back with details of your system. Computer & OS, FCP version, QT version, capture card, storage, external audio/video monitors, everything. We need more details to help you troubleshoot this.
debe
Rob Forsythe
October 9, 2005 at 8:21 pmThis list contains virtually everything to try to enable:
a. External Monitor VIDEO and AUDIO via FireWire & DV deck or camcorder.
b. Viewing in the Canvas window on the computer screen.
c. Being able to record on the external FW DV deck or camcorder.If working this list doesn’t cure the problem… you may have a PROBLEM!
Try things in this order until you find the “cure”:
1. Make sure you have only ONE (1) FireWire deck, camcorder, DV capture “card”, or D-to-A converter or video device attached to the computer at a time. Any more than one DV device can cause loss of signal and control.
2. Make sure you have View (Menu) > External Video> All Frames set.
(If the ALL FRAMES option is grayed-out… jump to step 6 below and continue.)
3. Make SURE your Canvas window (right window) in FCP is set to “Fit to Window”… AND that it has not been “pushed off” the edge of the computer screen.
4. Make sure your CANVAS View Menu (Box Icon with broken sides) is checked on Image or Image+Wireframe… NOT just Wireframe.
5. Make sure your CANVAS View Menu is checked on RGB… NOT just Alpha.
6. Make sure your Final Cut Pro (menu) > Easy Setup… is set for DV-NTSC (or DV-PAL, if that’s where you are).
7. Some camcorders/decks work better under “FW (NTSC/PAL)” -or- “FW (NTSC/PAL) Basic” control (in the capture settings). Try either setting to see which works best for your device.
8. Make sure your Final Cut Pro (menu) > Audio/Video Settings > A/V Devices (tab) > Mirror on Desktop > must be CHECKED. (If not, playing video will not appear in the Canvas.)
9. Make sure the “Log and Capture” Window is CLOSED and not just “hidden” behind other windows.
10. Turn off the power to the Camera/Deck/Converter Box, then turn it back ON.
11. Make sure the camera is in VTR mode… or the deck is in DV (DV, iLink, or FW) input.
12. On a Sony camcorder or deck, make sure the menu setting “A/V > DV Out” is set to OFF.
13. Re-check that your FW cable is well-connected at both ends (or try a new cable).
14. Important: Quit FCP, then Restart FCP.
15. Now again, make sure you have View > External Video > ALL FRAMES set…If it still does not work. “Trash” the FCP Preferences on the Mac
https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html“FCP Rescue” is a free Apple Script that will Trash the Preferences.
It will also restore your user settings afterwards.
Download:
https://www.macupdate.com/info.php/id/14729>Then, start again at my “step 1” above.
