Activity Forums Adobe After Effects Can’t Paste When Copied To Clipboard in Mocha
  • Can’t Paste When Copied To Clipboard in Mocha
    Posted by Ian Leo on February 4, 2011 at 11:56 pm
    Help! When I select copy to clipboard in Mocha, and try to paste the tracking data to a null object, I just can’t paste it. The “Paste” sign is not clickable. I have two versions of Mocha. Because I didn’t know that Mocha comes automatically with After Effects, I downloaded Mocha from the web. Then I found out the original Mocha. I tried both versions and I still can’t paste. Please help, thank you very much!
    David Marks replied 15 years, 4 months ago 4 Members · 5 Replies
  • Tudor “ted” jelescu
    February 5, 2011 at 5:37 pm
    Did you try what Dave suggested to your earlier? See if pasting data to a solid after you choose export from Mocha to Clipboard will do anything. Also, try pasting the data to a text file and see if that works. I will ask you again- are you exporting position track data or corner pin data?
    If you want answers it is common courtesy to answer back to the questions directed to you.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Ian Leo
    February 5, 2011 at 11:59 pm
    Yes. I have tried pasting it onto a solid and text layer, but its still won’t work. And I exported by transform data
    February 6, 2011 at 9:51 am
    Save the track data to a file- open that file, copy and then try pasting in AE.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Zhuang Ziyou
    April 24, 2011 at 12:21 pm
    I know why the data cannot be pasted~~~~ it has something to do with the fps setting. a same 23.98 footage in AE comp inported to mocha will be converted to 24 automaticly,thus AE wont recogonize the data exported….so you just have to adjust the fps setting while inporting footage~~~
  • David Marks
    May 8, 2011 at 8:33 pm
    Make your null a 3D layer and it’ll work.
