Activity Forums Adobe After Effects can’t parent comp to puppet tool deform point when continuously rasterize is on
  • can’t parent comp to puppet tool deform point when continuously rasterize is on
    Posted by Eric Bowman on February 25, 2009 at 10:41 pm
    So I have multiple comps that I want to parent to specific puppet tool deform points. For example I have a deform point for the kneck of a stick figure, and I need to parent the actual head comp to that deform point. It works fine if I pick whip the position of the head comp to the deform point, if I have continuously rasterize turned off (it’s a vector illustrator file inside the head comp). If I have it turned on it does not update unless I select Edit > Purge.
    Is this a bug with the Puppet tool?
    Eric Bowman replied 17 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
