Activity Forums Apple Final Cut Pro Legacy Can’t output video
  • Can’t output video
    Posted by Needs Realname update on August 17, 2005 at 8:34 am
    FCP 5, G5 and Tiger. Out of the blue my video output disappeared. I have a sony dsr 40 p firewire recorder. Audio still goes out to my recorder but not video. When I print to video it works, log and capture also.
    I have restarted several times and checked all my settings. Everything is new, computer and FCP and for two weeks now it has worked fine.
    Please help
    Wild Bill
    Needs Realname update replied 21 years, 1 month ago 2 Members · 3 Replies
  • Needs Realname update
    August 17, 2005 at 9:13 am
    I’ve lost audio aswell. No longer sure I had it in the first place.
    Wild Bill
  • Shane Ross
    August 17, 2005 at 9:53 am
    Shane’s Stock Answer #8:
    A simple path is mac > firewire > camera or deck > rca cables > tv
    Then start up your camera and tv, then open fcp.
    Then go View > External video > all frames
    Video playback should be Apple firewire NTSC (If you are using an NTSC set)
    Audio playback should be Audio follows Video
    Techinially, this should send synched video to your TV
    If for some reason you can’t view your timeline on your external monitor, there are a few things to try:
    1) Make sure that the camera/deck is connected and powered on BEFORE you open FCP.
    2) In the Final Cut Pro menu select AUDIO/VIDEO Preferences and make sure your signal is being sent out thru Firewire DV.
    3) Go to the menu and select VIEW>EXTERNAL>ALL FRAMES.
    4) Click in the % box above the image and select FIT TO WINDOW.
    5) Go to VIEW->refresh A/V devices
    6) Make sure the Log & Capture window is closed
    If you want it to play in both the canvas and the external monitor you need to go to the FINAL CUT PRO menu and select AUDIO/VIDIO settings and make sure MIRROR ON DESKTOP is selected under the PLAYBACK OUTPUT section
    For all the stock answers, click on this link:
    https://discussions.info.apple.com/webx?50@941.OTrRaOS9SEl.0@.68a3b883
    August 17, 2005 at 10:02 am
    Shane my hero, back on track. Thanks
    Wild Bill
