Activity Forums DaVinci Resolve Can’t output Stereoscopic convergence
  • Can’t output Stereoscopic convergence
    Posted by Thiery Roussel on July 13, 2012 at 1:26 pm
    I am not able to Output the adjusted convergence I’ve done Inside Resolve. The grading is there, but When reimport the DPX in after effects, no convergence at all. And I reimport the rendered DPX into Resolve, It seems to retain the convergence I’ve made… Kind a like it was only metadata??
    Any Ideas
    thanks
    Thiery Roussel replied 14 years, 1 month ago 1 Member · 1 Reply
  • Thiery Roussel
    July 16, 2012 at 1:08 am
    My bad,
    Find out I was adjusting the 2k plate convegence while monitoring in side by side. I was monitoring in 1080p, so every adjustments were off. Should have take a look at the anaglyph or difference, before outputing.
