Activity Forums Apple Final Cut Pro Legacy Can’t open Final Cut
  • Can’t open Final Cut
    Posted by Emy Fehmi on August 4, 2006 at 7:47 pm
    One of my external drives that i edit onto got unplugged by accident….and even though everything seems to still be there….now final cut pro won’t open.
    It goes through all of the regular process but at the end it just goes back to the Finder. I’ve tried restarting, and dismounting the drive and the program won’t even open on it’s own…I took the project to someone else’s computer and the project opens with some items missing (that are on the other computer).
    I’m not sure what to try next….
    Can anyone help? I’m lost without my computer…
    emy
    Giuseppe Valentino replied 14 years, 6 months ago 4 Members · 5 Replies
  • Winston A. cely
    August 4, 2006 at 8:55 pm
    Step 1.
    User>Library>Preferences>delete the file named “com.apple.FinalCutPro.plist”
    then….
    Step 2.
    User>Library>Preferences>Final Cut Pro User Data> delete files “Final Cut Pro 5.0 Prefs” “Final Cut Pro Obj Cache” and Final Cut Pro Prof Cache”
    Now restart FCP and everything should be OK. Step 2 is going to revert ALL of your user settings to the default FCP settings. You’ll have to go back and change all your user setting back to the way you had them, but depending, that’s not too bad a task.
    Hope this helps.
    “If God could do the tricks we can do, He’d be a happy Man.” – Peter O’Toole – “The Stuntman”
    Machine Model: Power Mac G5
    CPU Type: PowerPC G5 (3.0)
    Number Of CPUs: 2
    CPU Speed: 2.5 GHz
    L2 Cache (per CPU): 512 KB
    Memory: 4.5 GB
    Final Cut Studio (Not Universal, yet)
  • Emy Fehmi
    August 4, 2006 at 9:05 pm
    Thanks So much for the help!
    It worked and you saved the day!
    emy
  • Winston A. cely
    August 4, 2006 at 9:55 pm
    Glad I could help! 🙂 This is actually a question that comes up a lot here (“FCP won’t start”), and most people will ignore it. They don’t do it to be mean, but most of the people here only have a certain amount of time to devote, so if they see a question that’s already been asked and answered, they tend to go on to the next one. In the future, try a quick search and many times you’ll find the answer before you have to post, which is great cause it’ll same you the time of writing! 😀
    Hope things keep running feel speed ahead!
    Number Of CPUs: 2
    CPU Speed: 2.5 GHz
    Memory: 4.5 GB
  • Dean Puckett
    November 24, 2010 at 8:46 pm
    Thank you sooooo much winston you just really helped me alot
  • Giuseppe Valentino
    March 13, 2012 at 8:37 pm
    Thank you Winston, I just searched on the web if some people had the same kind of problem and I found your prompt answer here on creative Cow, I truly wanted to thank you for sharing it. I’m working on a serious one year long project and I was scared and you gave me a great help (although, answering somebody else).
    Well, thank you very much, maybe for you was a little thing but it was truly important for me to fix this problem, so thanks again and if you find the time maybe you could write why it happen so suddently that FCP didn’t open up.
    Thanks a million,
    Peppe
