Activity › Forums › Adobe After Effects › Can’t open comps
Can’t open comps
Posted by Sean Kimber on May 25, 2016 at 2:39 pmI’ve run across a new one all of a sudden. For some reason, I can’t double click on compositions in the Project window and have them open up. I’ve tried restarting my computer and reinstalling After Effects (without keeping my preferences) twice now. The behavior is still happening. It’s also happening across all projects.
In addition, when I double click a layer to change the inpoint in the composition window, the cursor stays at the end of the comp and won’t move.
I’m using a Mac Pro with El Capitan.
Anyone run across this behavior and have a solution?
Steven Perry replied 9 years, 4 months ago 6 Members · 8 Replies -
Sean Kimber
May 25, 2016 at 2:49 pmThis is happening with AE CC 2015. (13.1, I believe. It’s completely updated).
My OS is OS X El Capitan, Version 10.11.5
After Effects had been working properly, but something occured today all of a sudden that seems to have corrupted it.
Sean Kimber
May 25, 2016 at 2:57 pmAs an update, I installed CC2014. Everything works fine in there. So, something’s corrupt in CC 2015. I just am not sure why a clean install isn’t fixing that.
Soham Jani
May 25, 2016 at 3:19 pmAlright, I’m just gonna throw some stuff at you, catch them and see if they work.
1) Restart the computer.
2) Re-Install AE, or uninstall every Adobe product, and re-install.
3) Run as Administrator.
4) Clean imstall of the laptop?? (Last resort-backup your stuff!)
5) Blame it on Obama.\”It\’s all around us Neo, temporary constructs of time…..\”
Sean Kimber
May 25, 2016 at 4:05 pmI’ve tried most of those. I did a completely clean install, trashing every AE preference I could find. It fixed the problem. I worked for about 20 minutes, and the problem came back. I had to trash my preferences again to get things to work properly. So, I’ve narrowed down the problem, but I’m not sure where to go from here.
Thanks, Obama.
Peter Lee-jones
September 15, 2016 at 10:58 amI have this problem as well. When I try to open certain comps from the Project window they fail to open in Timeline window.
When I import a new .ai file as a comp that is un-openable as well.
However, if I right click and select New Comp from Selection then the resulting New Comp opens in the Timeline!!
You can then double click on the nested Comp and that opens the original in the Timeline!!!
That’s a neat work around 😉
Thanks Adobe for adding this useful feature.
– Pete
– Senior Editor, Pinewood, UKAE 2015.3 release 16GB OSX 10.11.1
Pinewood Studios, UK
Fernando Pauwels
November 7, 2016 at 9:28 amHad the same thing occur to me… changing the workspace did the trick… hope someone is helped by that… 🙂
Stefan Zerdzinski
November 21, 2016 at 12:19 pmI just experienced this issue too.
I can confirm that resetting the workspace has fixed the problem. -
Steven Perry
May 9, 2017 at 5:55 pm*Here’s your answer* Most likely…
(Assuming you’re using 2 monitors)My buddy just had this problem.
The issue is you have a panel open for a plugin (say duik, after ease, cloners and effctors, textor, or heck, even your effects window, text, paragraph, preview, etc.) This is on your second monitor, but slightly overlapping your project window.Mac only renders that window on the second monitor, because it thinks that it should only be on that monitor, but unfortunately it will keep you from clicking on things underneath it on your second monitor(at least in after effects).
So when you try to open comps, you’re not actually clicking on your project panel, but another floating panel that is not visible because MAC is only rendering that window on your second monitor.
MS Windows doesn’t have this problem, because on windows you would see it overlapping your project panel.
This is why resetting your project space works, because it’s going to close that panel, or move it to where the default space thinks it should be.
