Activity › Forums › Boris FX Particle Illusion › Cant open background
Posted by Hexatron on May 23, 2005 at 5:34 pmHi,
In particleilluson, I can’t open a background image, it says its an unsupported file format, how can I fix this?
Thankyou.Hexatron replied 21 years, 4 months ago 3 Members · 6 Replies -
Alan Lorence
May 23, 2005 at 7:30 pmWhat type of image are you trying to load? particleIllusion does not support every image format available.
Alan.
wondertouch -
Aharon Rabinowitz
May 24, 2005 at 2:39 pmI think I understand. Are you trying to open it through the “file -> Open” command?
That’s used to open pillusion files, not images.
To import an image do the following:
In the layer window (Top Left), double click on the gray box – it will open a dialog asking you to locate the BG image you want to import.
Check out this tutotorial to learn how to put particles over Background footage:
https://www.wondertouch.com/tutorials/aharon/basic/Tut_1.htm
Aharon Rabinowitz
aharon(AT)yahoo(DOT)com
http://www.allbetsareoff.com
Creative Cow Master Series DVD
particleIllusion Fusion Volume 1
available @ http://www.pIllusionFusion.com -
Hexatron
May 24, 2005 at 3:01 pmI am doing that, Using the layers window, and it says ‘Unsupported File Format’ no matter which image I use
Alan Lorence
May 24, 2005 at 3:10 pmI don’t think you have a complete installation. I recommend reinstalling.
Alan.
wondertouch
