Can’t move one of my objects…
Hi all, having a bit of an odd issue here…
I created a simple ribbon of Police Line tape for a video i’m working on, using planes and cloth surfaces, and it came out pretty nice I think… except, for some reason, I suddenly can’t move the object… I can’t scale it, I can’t rotate it, but the important thing is I can’t even move it. It seems that when I move the object, it sort of “pulls” on it, like it’s trying to move it, but it snaps right back into place…
If I create new objects, like a cube for example, I can move those around no problem. But my police ribbon just won’t budge. Any ideas?
Just for a heads up, Axis Modification isn’t enabled, so it isn’t that.
Also, because it’s an animated cloth object, the two sets of points on either end are “set” as fixed points in the Cloth > Dresser properties of the plane… but that is so it can animate properly. Without those, the object just falls to the floor. And, just in case, I have indeed tried deleting these fixed points / anchors just in case… still couldn’t move the object.
Thanks 🙂
(I’ve attached the save file in case anyone wants to take a shot at it…)
