Can’t Move FCP 24pA footage to AE
Hello,
I am currently editing a short in FCP that has a number of visual effects that we need to move into AE for. Here’s the stats on everything we’re running:
FCP 6.0.5
p2 footage from HVX-200, shot @ 1080 24pA
FCP ingested via Log & Transfer using DVCPRO HD 1080p30 (this was what fcp defaulted to)
we are trying to move over to Windows AE CS3We have a picture lock cut inside fcp, but when exporting to DVCPRO HD 1080p30 quicktime files, there is an error on the AE end that AE cannot read the codec. So my question is, is there a different/better way I can do a lossless export out of fcp so that my FX guys can work in AE and then return footage to me? Are all the above settings ok, or should we not be in 1080p30? I’m new to working with p2 footage so I just wanted to make sure I didn’t bork the import and that we don’t have to start over.
Thanks again for any help you guys can provide. If it turns out I’m ok on the fcp end and this is an AE problem, let me know and I’ll post this on the AE forums.
– Matt
