Activity Forums Apple Final Cut Pro Legacy Can’t Media Manage a Project
  • Can’t Media Manage a Project
    Posted by Paul Jones on February 11, 2011 at 2:48 pm
    I hope someone can help me.
    I have just finished a project on FCP7, all the assets are Pro Res 422 HQ 1920 x 1080.
    When I try and media manage the project it fails with error code 34.
    I’ve rebooted, reset PRAMS-Prefs etc etc and still the same.
    I have never had this problem before and seems to be only on this project.
    And help appreciated or any other suggestions to backup the project
    Cheers
    John Heagy replied 15 years, 6 months ago 4 Members · 4 Replies
  • Mark Raudonis
    February 11, 2011 at 3:22 pm
    Do all your clips have “reel numbers”?
  • Paul Jones
    February 11, 2011 at 3:36 pm
    Yes they have reel name
    It was material shot on Alexa and converted to pro res HQ….example of a reel name is A003R10A
  • Scott Stolzar
    February 11, 2011 at 9:04 pm
    Does it fail immediately or go for a bit and then fail?
  • John Heagy
    February 12, 2011 at 5:08 pm
    Alexa camera original QTs are a bit “off” for lack of a better word. Not too surprising given the lack of any coherent documentation to guide developers on QT best practices. The QT API is a patch work that spans decades, and there are dozens of way to do things. The few Apple QT recommendations don’t work in FCP. ARRI simply picked a path that cause issues FCP.
    I don’t know how much footage you have, but doing a “Save as…” in QT player should “fix” the ARRI camera original files. You can also try a batch Export in FCP or use CatDV to export new movies. You may be able to export reference movies which would save export time, but self contained may be necessary.
    Once you have the new movies, re link them to your project and try your Media Manage again. I’d suggest doing a test using the above techniques to find which works the best and fastest before exporting all your Alexa footage.
    Arri needs to fix their files.
    John Heagy
