Activity › Forums › Adobe After Effects › Can’t Make Layers Disappear in Timeline – Imported PSD as Comp
  • Can’t Make Layers Disappear in Timeline – Imported PSD as Comp
    Posted by Stewart Goldstein on August 23, 2005 at 4:55 am
    I tried importing a PSD with a number of layers as a Composition. I selected “Composition” as opposed to Footage.
    Why can’t I make some layers disappear when I click on the eyeball in the timeline? I even tried clicking the eyeball on every single layer, but there was no change in the layers.
    Mike
    Stewart Goldstein replied 21 years, 1 month ago 2 Members · 2 Replies
  • Steve Roberts
    August 23, 2005 at 12:36 pm
    Which window is open? The composition window or layer window? You should be seeing the comp window.
    Do you have a layer soloed? A solo layer can affect the visibility of others.
    Steve
  • Stewart Goldstein
    August 23, 2005 at 2:56 pm
    I have the timeline window open, among others.
    I’m not sure what a “soloed” layer is; would that be something from v 6 or later? I have 5.5.
    I imported a PSD and selected to import is as a comp, I opened up the comp in the timeline, where I can see each Photoshop layer as a layer in the comp. When I try to toggle the visibility of any layer, they don’t disappear.
    Thank you for your reply.
