Activity Forums Apple Final Cut Pro Legacy Can’t make a non-self-contained movie
  • Can’t make a non-self-contained movie
    Posted by John Felt on April 29, 2008 at 6:21 am
    Hi all
    Has anyone else had this problem? I am trying to export an hour long movie, and I’d like to make it not self-contained so I can quickly bring it into compressor. However, Final Cut refuses to recognize that I unchecked the box that says “make movie self-contained”. Am I missing something else?
    Thank you all for any help you can provide. It is much appreciated.
    John
    Jeremy Garchow replied 18 years, 4 months ago 6 Members · 11 Replies
  • 11 Replies
  • Zane Barker
    April 29, 2008 at 6:36 am
    How big is the file it gives you? Non Self contained fils still can have some weight in the size. Try and play the file on another computer or disconnect your media drive and see if it still plays.
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • John Felt
    April 29, 2008 at 6:46 am
    The files are like 12 gb for an hour- the same amount as a self-contained file. The weird thing is that I have another sequence in the same project that I was able to export as a reference file and it was like 1.03 gb.
    Any other thoughts?
    Thanks again!
    John
  • Zane Barker
    April 29, 2008 at 6:52 am
    Did you try playing it on another computer or after disconnecting all media drives?
  • Jeremy Garchow
    April 29, 2008 at 2:04 pm
    Make sure your movie is completely rendered before exporting, otherwise it will render while you export and make a large movie. That includes turning on the full options in your render all and render selection menus under Sequence.
    Jeremy
  • Paolo Ciccone
    April 29, 2008 at 2:26 pm
    What codec did you select for the compressor of the sequence? Codecs that use temporal compression, like HDV and MPEG, cannot be used for a QT reference movie as they require to rebuild the GOPs. Also the sequence has to be fully rendered in order to get a reference movie as QT needs to create pointers to the renderfiles
    Paolo Ciccone https://www.paolociccone.com
    Hellriser Digital
    Santa Cruz, CA
  • Rafael Amador
    April 29, 2008 at 3:02 pm
    [John Felt] “like 12 gb for an hour- the same amount as a self-contained file”
    [John Felt] ” I was able to export as a reference file and it was like 1.03 gb.
    Your FC must have something really wrong. A really would be scared of a Refference movie of 12Gbs or even 1Gb. You can get quite big Project files when the project contains many footage, sequences, layers, effects, etc. But a QT Reffrence movie in just a “play-list” pointing to clips.
    Mac OX 10.5.2-FC 6.02-QT 7.4.1
    G5 2x2Gh 4GbRAM-BlackMagic Extreme
    PMBP 17″Core2Duo 4GbRAM-AJA ioHD
    JVC DTV-17″
    SONY EX-1 . SONY PD170
    ..and always a big mess on top of the table.
  • John Felt
    April 29, 2008 at 3:33 pm
    Thank you all for your responses. I am using a DV codec, and exporting with current settings. It is fully rendered.
    Any other thoughts?
    Thanks again for all your help,
    John
  • Jeremy Garchow
    April 29, 2008 at 3:41 pm
    [John Felt] ” It is fully rendered.
    Are you absolutely sure? Sorry to harp on this, but you have to go to the Sequence > Render ALL and Sequence > Render selection menus and make sure that all the options are checked, including ‘full’. By default these options aren’t checked.
    Jeremy
  • Martin Baker
    April 30, 2008 at 7:05 am
    What version of FCP are you using John?
    Martin
    Digital Heaven, London UK
    Unique plug-ins and tools for Apple Pro Apps
    Avid2FCP
    For Avid editors learning FCP
  • John Felt
    April 30, 2008 at 7:09 pm
    OK! That seems to be the problem, that it wasn’t “full”y rendered.
    However, it does leave me a little perplexed:
    The reason it needs to render is that I added color correction to the entire hour and a half. Is that normal that it would need to render it? I have never seen that need before.
    Anyway, thank you all for your help. It is greatly appreciated.
    John
