Activity › Forums › Adobe After Effects › Can’t locate extra plugins on AE Installation Disc??
  • Can’t locate extra plugins on AE Installation Disc??
    Posted by Jonathan Dean on January 12, 2009 at 4:43 pm
    Hi there
    Trying to follow a tutorial in AE but I need the cc particle world plugin… Ive read everywhere its an extra installer on the AE disc but I jus can’t see it? Im using a mac and I think Im just not used to the finder… is it really obvious and am I just being stupid?? What is the folder name I should be looking for with the extra installers on it?
    Thanks guys
    Kevin Camp replied 17 years, 8 months ago 2 Members · 1 Reply
  • Kevin Camp
    January 12, 2009 at 5:13 pm
    for earlier versions of ae (ae7 and earlier) the extra plugins were on the install disc in a folder called ‘extras’, and were only available on the pro version of ae (not the standard, educational or trial versions). later versions (cs3, and i assume cs4) installed them by default with the normal installer (note: there is no ‘standard’ version anymore and i’m not positive if the extra effects came with the educational or trial versions, but i think they do with the educational version).
    if you have cs3 or later, and had modified the install to not include third-party files, then you should be able to use the installer to install only the third-party files in the custom install settings.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
