Activity › Forums › Adobe Premiere Pro › Cant load old project in Premiere 6.5
  • Cant load old project in Premiere 6.5
    Posted by Mat Jay on January 27, 2006 at 11:31 am
    Hi
    I came to this site via the excellent podcasts which I listen to regularly.
    I wonder if anyone can help me with a problem I’m having in Permiere 6.5?
    When I try to load an old project into Premiere I have a dialog asking me to Locate A File. When I show it the file I get a dialog box stating “The media type of the selected file is different from that of the missing or offline file…” It asks me this for every single video (well over a hundred)
    The file I select is the correct one, all files have been left on my hard disk and not even moved, I’m using the same version of Premiere as I originally used.
    Does anyone have an idea?
    Could it be a codec issue? – all videos are DV files. I’m pretty sure XP (SP2) has a microsoft DV codec built in though.
    I’d be very grateful for any help.
    Many thanks
    Mat
    Mat Jay replied 20 years, 8 months ago 2 Members · 2 Replies
  • Tim Kurkoski
    January 27, 2006 at 4:47 pm
    How old is the project? What version of Premiere did you create it with?
    Are you using a capture card with Premiere, or did you when you created that project?
  • Mat Jay
    January 27, 2006 at 5:10 pm
    Hi Timothy
    It’s a couple of years old. I’m pretty sure I used 6.5 or 6 at the oldest.
    You’re right I did have a DV camera connected via a firewire card, which I dont have now. Could this be the cause?
    I’ve just downloaded a Panasonic DV codec, and now it loads! Excellent!
    Thanks Timothy!
    Mat
