Activity Forums VEGAS Pro Can’t load AVI file
  • Can’t load AVI file
    Posted by Jon Banquer on November 6, 2011 at 3:20 am
    I can play the .avi file on my computer with VLC Media Player but I can’t load the file into Sony Vegas Pro 11. What can cause this problem to occur?
    Joao Carlos schwalbach replied 13 years, 6 months ago 4 Members · 10 Replies
  • 10 Replies
  • Mike Kujbida
    November 6, 2011 at 9:09 am
    Run GSpot or MediaInfo (both are free) on the file and let us know what it says about the codec needed.
    Please do not, under any circumstances, install a codec package of any kind.
  • Jon Banquer
    November 6, 2011 at 5:12 pm
    Thanks for the response, Mike. I downloaded and installed MediaInfo. MediaInfo says the Codec for the .avi I can’t load into Sony Vegas Pro 11 is XviD.
  • Mike Kujbida
    November 7, 2011 at 2:37 pm
    Jon, you can get the Xvid codec at https://www.xvid.org/
    I’ve never installed it and know that some folks don;t recommend doing so.
    If you do want to go ahead with it, make sure to set a restore point so that you can go back if you have to.
  • Jon Banquer
    November 7, 2011 at 2:47 pm
    Mike, why do I need the Xvid codec if I can play the video with VLC Media player but it won’t load into Sony Vegas Pro 11?
  • Mike Kujbida
    November 7, 2011 at 2:59 pm
    Unlike Vegas, players like VLC have a lot of decoders already built into them.
    Without the Xvid codec installed, Vegas won’t be able to read the file.
  • Jon Banquer
    November 7, 2011 at 5:56 pm
    I’m running Windows 7 64bit. There is no way to uninstall a codec if it gives me problems? Why would a codec cause so many problems that I have to restore Windows 7? What are the kind of problems the system will experience if the codec is “bad”?
  • Stephen Crye
    November 7, 2011 at 10:37 pm
    I’ve grown to hate the xvid codec. Xvid files always give me fits with Vegas. It is waaay to compressed. I’d recommend converting the file to another format.
    This link sums it up nicely:
    https://www.foolishpassion.org/vidding-tips/vegas-won%27t-open-avi.html
    Good luck!
    Steve
    Win7 Pro X64 on Dell T3400 MultiTB SATA 8 GB RAM Vegas 10e x64 DVDA 5.2 Sony HDR-CX550V
  • Jon Banquer
    November 7, 2011 at 11:08 pm
    Hi, Stephen. I don’t have a problem with converting the .avi to another format to prevent problems. Should I convert the .avi to Lagarith AVI with VirtualDubMod?
  • Stephen Crye
    November 10, 2011 at 7:08 pm
    I use HuffYUV and VirtualDub all the time. I hear Lagarith AVI is good, worth a try.
    Steve
  • Joao Carlos schwalbach
    March 14, 2013 at 7:49 am
    Hello,
    I am also having problems loading an .avi file.
    Opened it with MediaInfo and this is what it show me:
    Video
    Format : MPEG-4 Visual
    Codec ID : DIV3
    Codec ID/Hint : DivX 3 Low
    Duration : 1h 9mn
    Bit rate : 1 305 Kbps
    Width : 512 pixels
    Height : 384 pixels
    Display aspect ratio : 4:3
    Frame rate : 25.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.265
    Stream size : 648 MiB (93%)
    Do I need to convert this before loading it into to vegas? And how do I do it?
    Or do I have to install a codec? And which one?
    I am using Vegas Pro 12.
    Thanks in advance.
    Kind regards,
    joni
