Activity Forums Apple Final Cut Pro Legacy Can’t Letterbox 16X9 sequence
  • Can’t Letterbox 16X9 sequence
    Posted by Babcut on February 28, 2006 at 2:17 am
    Help! I have an anamorphic sequence that I need to output letterboxed for VHS approval. For two months
    now I have outputting rough cuts by dropping my 16 x 9 sequence into a 4 x 3 timeline and its perfect.
    But now all of a sudden it doesn’t work with my current sequence (which is a copy of the earlier ones). A
    sequence from two weeks ago works fine, but not the current one. I have trashed prefs, but that did nothing.
    Any workarounds, bailouts? Thanks!
    Real Life is Your Best Entertainment Value
    Tom Matthies replied 20 years, 6 months ago 4 Members · 5 Replies
  • Trent Mitsuoka
    February 28, 2006 at 5:30 am
    Did you try exporting a self comtained movie and droping it into a 4×3 seq? or is that what you did?
    Trent Mitsuoka
    http://www.videonerd.net
  • Babcut
    February 28, 2006 at 1:05 pm
    No I should be able to just take a sequnce within FCP and drop it into the 4 by 3. What I ended up doing late last night was copying the attributes from an earlier letterboxed sequence and copying those onto the new oneA workaround, but successful and I didn’t need to take the time to export.
  • Tom Matthies
    February 28, 2006 at 2:32 pm
    Weird.
    I just had the same thing happen last week. I tried to take a 16×9 sequence and drop it on a 4×3 timeline for an analog tape. It usually works just fine, but this time I couldn’t get it to work no matter what I did. I ended up adding a distort factor to the anamorphic sequence and rendering it. I usually don’t have any problems doing this, but this time it simply refused to work.Strange…
    Any insights to this?
    Tom
  • Wayne Carey
    February 28, 2006 at 3:50 pm
    Is everybody using FCP 5.0.4? I, too, have had the same problem since going with the FCP 5.0.4 upgrade.
    _____________________________
    Wayne Carey
    wcarey@strikeking.com
  • Tom Matthies
    March 1, 2006 at 3:57 am
    Actually in this case it’s on a machine running 4.5 and OS10.3.7.
    Sometimes it works, sometimes it doesn’t.
    Tom
