Activity Forums Maxon Cinema 4D Can’t interpolate keys without changing the position path?
  • Can’t interpolate keys without changing the position path?
    Posted by Daniel De silva on April 18, 2018 at 8:51 am
    Hi there,
    Just wanted to post a quick question as wasn’t sure if I’m missing a step. Below I have animated an object using all x/y/z axis at the same time, a ball producing an infinite shape.
    I’d like it to speed on the straight, slow down arcing into the corner then gain speed again on the way out.
    However, obviously adjusting the bezier curves on the F-curve graph will change the path, not the speed.
    How is this normally done?
    Screen attached.
    Thanks for your help,
    Dan.
    Daniel De silva replied 8 years, 5 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    April 18, 2018 at 1:16 pm
    The easiest way to do this is to use a Time Track. I did little video tutorial on this a while back: https://www.youtube.com/watch?v=q6AuonzrDJ4&t=11s
  • Daniel De silva
    April 18, 2018 at 1:58 pm
    Ah ok that seems very useful, so It’s basically a time remap for C4D?
    Dan.
